change sip and https prot
aminbaik88
I tried to install a new PBX on a Linux VM.
I don’t have any option to change the port or other settings, so I downloaded the setup config file and tried to change the ports inside it.
After I modified the file, the certificate and password were no longer accepted.
Do you have any suggestions?
Yes, just for confirm you mean the time different?
No the link I sent you was to modify the ports, then you'll upload your XML during the install of the PBX.
what is your end goal?
yes that i tried ... once i update the file is give me always password error when try to upload cert
shall i include it in xml ?
I already change as below
once i upload the cert and put the password its give me wrong
if i tried to put the original file it works fine.
Syedx91
