Change SMTP settings after upgrading to V20 from V18
Cliffstone
My 3CX instance was original setup using V18 and under that version one could set the system to use their own SMTP server. And that is what I did. Works great. And my settings survived the in-place upgrade to v20. However, I am now in the process of migrating to a different email host and need to update my SMTP settings. It seems that 3CX decided to remove the access to SMTP settings for non-Pro licensed systems and forces you to use their servers for email. Well that's fine and dandy and all but it's still pointing at my custom smtp provider I setup years ago. How do I update it? If I cannot change the custom smtp settings, how do I set it to use the 3CX server?
Can you please create a case to the Customer Care Team from the below contact form to clarify further?
• https://www.3cx.com/contact/
He is using the free 3cx from v18 and cant change the email settings to custom or back to 3cx. Thats his problem.
You can try to modify your backup and restore it to use 3cx smtp.
I checked my own pbx, you will find the stuff under parameter in your pbx and can change it there.
also change the parameter MLFROMADDR to empty
Thanks for the tips. But I do not have access to the "Parameter" section. This may be because I am in the "System Owner" role perhaps?
Hi Cliffstone
Please use the menu option 'Advanced', there you will find 'Parameters'.
Check with the answer of bitn2
Paulo
Reactions: bitn2
Ah yes. Too early in the morning after a sleepless night. I made the changes and restarted the server. But it still sends through 3cx.net. So I guess they have coded it to ignore these settings on a free / personal license. Ugh. To me that seems like a pointless thing for them to do.
That's what you want in your post... You cant use your own smtp.
LeeonLau
