Solved Changing IPs
jimbo59
I had to change a block of IP addresses and it should have gone smoothly but I ran into the strangest problem.
I switched the addresses from Comcast, modified the router/firewall, and told Flowroute where to trust me. Picked up the phone and was able to call myself Friday night. Monday morning call from user can't hear other side of call. I checked the firewall and it was okay. Flowroute wanted a packet capture from our exterior IP address. I wasted a couple of hours and as a last ditch grasp, I deleted the trunk for Flowroute and recreated it and viola...all systems nominal.
Hope this helps others.
Did you also tried to clear DNS cache first?
Where were you? Much better idea. I had rebooted multiple times. I got lucky with what I ended up doing. Anybody seeing this delete the DNS cache first. BTW this is for an 8 user Pro package v20 locally hosted.
You may keep it as an idea for next time though...Have a great day ;)
ARKC
