Solved CID Building rules
Elandre
Good day everyone,
My Voice provider requires of me to have numbers being dialed in this format 012 345 6789 but numbers are saved in +27 12 345 6789, the +27 represents a 0 in South African dialing codes.
Could anyone kindly assist me with building an outbound reformatting rule to replace the +27 with a 0.
+27 12 345 6789 must reach the voice provider in this format 012 345 6789
Any assistance would be greatly appreciated.
Thanking in advance :)
Hi there Saqqara,
Thank you very much for your response, some numbers in the contacts list are already in the correct format. I assume that setting would remove the 012 345 6789 and dial 345 6789?
In the outbound rule , 'Apply this rule to these calls' with prefix +27 and then strips 3 digits (this will remove +27) and append 0
Also check your E164 settings, under Settings
All resolved, thank you very much for your assistance.
EMMEPICASA
