Cisco SPA112
greatchoice
Looking to see how I can provision this ATA device. I have a few other non supported devices as well. I use a SBC.
Any non-supported devices would have to be configured manually.
Correct
I’m guessing the proxy IP and theUN/PW on the device tab as a default?
That would be a good start. There's only so many combinations to try.
What do i use as the proxy though? The public IP or the FQDN?
Public IP or FQDN should be the same if properly resolved
If the ATA is not behind an SBC and the 3CX server is behind a static IP, then you can use that, if you wish. If it is a dynamic IP, then best to use the FQDN.
If the ATA is behind an SBC, then you will use the local IP of the SBC
Reactions: AWS2P
Cloudstar
