Connect XCapi to 3CX
Tappsy
Hi!
I am trying to connect our faxserver which is using XCapi to our 3CX. XCapi supports 3CX but i am not able to register the software to 3CX. I created an extension and followed the guidelines, but i am getting the following error.
Code:
23.11.2020 16:27:16 - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from faxserverip:5060 tid=15e9e8b1da4cae1bad010f77424462b5 Call-ID=6E9BAB2DEE01D6D10B802923BE84E16CD689F52A30@faxserverip:
REGISTER sip:3cxip SIP/2.0 Via: SIP/2.0/UDP faxserverip:5060;branch=z9hG4bK15e9e8b1da4cae1bad010f77424462b5
Max-Forwards: 70
Contact: <sip:Auth.-ID@faxserverip:5060>
To: <sip:Auth.-ID@3cxip>
Call-ID: 6E9BAB2DEE01D6D10B802923BE84E16CD689F52A30@faxserverip
CSeq: 96 REGISTER
Expires: 1200 Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS
Proxy-Authorization: Digest
username="Auth.-ID",realm="3CXPhoneSystem",uri="sip:3cxip",nonce="414d53595fbbd4d316:c68205c5d96d09bc5cb452042b456ec6",response="784bf8df41772a20b54bfd88be6b4414",algorithm=MD5 Supported: timer
User-Agent: www.te-systems.de XCAPI V3.6.100.0
X-XCAPI-UUID: 9BAB2DEE01D6D10B802A23BE84E16CD6 Content-Length: 0
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
I created a new extension and first i was not sure which username and password i would have to take, so i tried both: extensionnumber with webinterface-password and auth-id with the password, but both don't work.
Does anyone have an idea what to check?
We are using Version 16.0.655
Kind regards!
If anyone else will have to do the same just switch to "all options", go to "SIP" then enter the extension to username, auth-id to username (authorization) and the password. Then it works.
Thread can be closed.
Kind regards
Reactions: N_G
Glad you figured it out. Since you said Xcapi supports 3CX I was going to say you should go ask them for help since it doesn't work the other way (3CX supporting Xcapi).
tohoken1
