Implemented Copy an existing extension
3CX-IDEAS
Ability to be able to copy an existing extension and then be prompted to enter new extension number and the provisioning information if required
Upvote 82
Yes this makes sense, we know and we will consider it for implementation.
Agree. POne way - let us save a set as a BLF template to be used later.
If you take to the phone level that could also be great - as then screen timeouts, etc could be covered as well.
+1
This is really needed. there are just too many mistakes made in having to have 2 browsers open and to copy and cross check each extension setup
I just downloaded the v16 RC and tried this out it is wonderful thank you so much. :)
Reactions: accentlogic
I just looked at this in the V16 RC. It only makes a copy from one extension to a new extension. I put in an extension number that was existing and it told me "Given DN number cannot be used"
That's because extensions must be unique
ourladyofguadalupeamarill
