Create contacts or leads automatically the same as in the previous version
thiago.lemos@nassautecnol
In Update 8 of 3CX v18, the way in which the operation works for customers not registered in the CRM to no longer create a contact with a default name was changed. Instead, from the Web Client you can decide whether you want to create a contact or not and define the contact details.
In the new version, is there any way for the system to automatically create contacts the same as before?
ok thank, I will look
Graham Robertson
