CRM CUSTOM calling number field
eroe33
Gold Partner
from our 3cx we are using, as an integration with CRM, the possibility of inserting into our db as per the 3cx documentation:
INSERT INTO 3cx_log VALUES (NULL,'[CallType]','[Number]','[CallDirection]','[Name]','[EntityId]','[EntityType]','[Agent]','[AgentFirstName]','[AgentLastName]','[AgentEmail]','[Duration]','[DurationTimeSpan]', STR_TO_DATE('[DateTime]', '%d/%m/%Y %H:%i:%s'),STR_TO_DATE('[CallStartTimeLocal]', '%d/%m/%Y %H:%i:%s'),STR_TO_DATE('[CallStartTimeUTC]', '%d/%m/%Y %H:%i:%s'),'[CallEstablishedTimeLocal]','[CallEstablishedTimeUTC]',STR_TO_DATE('[CallEndTimeLocal]', '%d/%m/%Y %H:%i:%s'),STR_TO_DATE('[CallEndTimeUTC]', '%d/%m/%Y %H:%i:%s'),NOW())
In the various fields there is no calling number field but only extension and called number since it is present in the cdr file: is it possible to also have the calling number in the insert into or another way to externalize this data?
Thank you
Thank youHowever, I can't find the parameter for the calling number in the list: is there the possibility of using it as a parameter? It is not present both in the xml template indicated and in the SQL parametersThank you
The @Number parameter contains the caller's number. The @Agent parameter contains the extension number that receives the call.
Ok @number and @Agent, but there is, as present in the cdr, a “from-no - Source caller number” field; the data is useful since from an extension the user can use different outgoing numbers.
That information is not available for the integration template.
