CRM integration to V20
REDFAC
We are trying to integrate custom CRM to 3cx via Rest Api, created client id and secrete still not get any response. Is it mandatory to create template as well as.
The CRM integration doesn't work via the REST API but via templates. So yes, you need to create one and let go of the XAPI/CCAPI as it won't help you.
Ok, so we have to create a template and upload in system, but it will work without client id and secrete right,
Hi, we successfully added Template and gets the result, now need to know, if someone make calls. the call details will be synced with CRM or not?
Is this proper,
If you have the call journalling enabled on your CRM configuration then yes, this should send the call information to the CRM after each call.
Is it possible to send call recordings to CRM?
Or only call details.
In template wizard, no filed is there.
Thanks.
Thanks.
[RecordingUrl]
The wizard hasn't been updated in a while for all the changes.
So we need to add this filed right
You add it manually. We don't use the editor/wizard but it should let you add it.
We code directly in the XML, it's easier for us lol
You can also leave that as a variable, no need to hardcode it in the XML. You can let users configure it when needed.
Failed to send FCM PUSH to device motorola moto g84 5G(Ext.104). Received error from server: NotFound: Not Found. Find more info at: https://firebase.google.com/docs/reference/fcm/rest/v1/ErrorCode
This error comes while we are trying to add extension via QR in the same wifi, but other networks its fine. And there is call disturbance.Kindly help how we can solve.
Thanks,
This is now working without any issue
Hi Nicholas,
We successfully imported templated and while testing response is receiving from CRM, but when actual calls done, nothing is pushing towards CRM, could you please help.
Thanks,
intoxtech
