Crm With Syonet
thiago.lemos@nassautecnol
Dear all, this crm's api only delivers this information. How could we make XML with just this data?
Testing in Postman I get code 200 ok and response
"status": 0
How this integration would be done, the CRM team informs that with other systems it works fine with this API, as it is the only one developed by them.
Below is the crm api data:
Open pop-up screen for operator
● Tipo: GET;
●Endpoint: IP_SERVER_CRM:4002/?ddd={ddd}&phone={number}&agent={agent}&callid={callid}&ip={IP_PBX}
Parameters received in the request
Parameter name​
Mandatory​
Type​
Description​
ddd (Area Code)​
yes​
String/text​
Call area code​
phone​
yes​
String/text​
Call telefone number​
agent​
yes​
String/text​
Telephone agente identification number​
ip​
yes​
String/text​
Ip of the telephony server that contains this connection​
Example:
client.crm.com:4002?ddd=11&phone=9999999&agent=1082&ip=pbxserver.com
You will need to use the Open Custom URL in the Webclient, and hardcode the agent on each Webclient.
ok, I understand, I'll test and feedback
Just passing by to say that it worked just fine.
EMMEPICASA
