Custom Integration Call Type Values not correct
pierremueller
I have implemented a custom integration to report calls, using the provided XML template and SQL Statement.
However, calls which should have had CallType = 'Unanswered' or 'Missed', seem not to be logged.
Any idea what is happening?
Template:
Code:
<?xml version="1.0" encoding="utf-8"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="US" Name="EventInc Custom Integration" Version="1" SupportsEmojis="true" ListPageSize="0">
  <Number Prefix="AsIs" MaxLength="15" />
  <Connection MaxConcurrentRequests="2" />
  <Parameters>
    <Parameter Name="Server" Type="String" Parent="General Configuration" Editor="String" Title="Server:" />
    <Parameter Name="Port" Type="String" Parent="General Configuration" Editor="String" Title="Port:" />
    <Parameter Name="Database" Type="String" Parent="General Configuration" Editor="String" Title="Database:" />
    <Parameter Name="Username" Type="String" Parent="General Configuration" Editor="String" Title="Username:" />
    <Parameter Name="Password" Type="Password" Parent="General Configuration" Editor="String" Title="Password:" />
    <Parameter Name="ReportCallSQLStatement" Type="String" Parent="General Configuration" Editor="Sql" Title="Call Journaling SQL Statement:" />
  </Parameters>
  <Authentication Type="No" />
  <Scenarios>
    <Scenario Id="ReportCall" Type="SQLDatabase">
      <Query DatabaseType="PostgreSQL" ConnectionString="Server=[Server];Port=[Port];Database=[Database];User Id=[Username];Password=[Password]" StatementPasses="2" Statement="[ReportCallSQLStatement]" />
      <Variables />
      <Outputs AllowEmpty="false" />
    </Scenario>
  </Scenarios>
</Crm>
SQL Statement:
Code:
INSERT INTO calls (agent_extension, agent_firstname, agent_lastname, agent_email, number, call_direction, call_type, call_starttime, call_endtime) VALUES (@Agent, @AgentFirstName, @AgentLastName, @AgentEmail, @Number, @CallDirection, @CallType, @CallEstablishedTimeLocal, @CallEndTimeLocal)
Set the system to verbose, do a couple tests and then check the Activity Log > Logs > Instance > 3CXSystemService.log
If you're on v20, you'll need to download the Support Info to get the log files.
Reactions: edossantos
All right, what exactly should I be looking for?
I have access now to the verbose logs and I have downloaded teh 3CXSystemService.log
Search for "CRM:"
You will see things like "Preparing to report call with data: ..."
Oh, I found the error.
Code:
2024/01/29 15:06:03.855|2828|0057|Erro|CRM: Exception during call reporting: Npgsql.PostgresException (0x80004005): 42703: column "callestablishedtimelocal" does not exist
POSITION: 185
   at Npgsql.Internal.NpgsqlConnector.<ReadMessage>g__ReadMessageLong|233_0(NpgsqlConnector connector, Boolean async, DataRowLoadingMode dataRowLoadingMode, Boolean readingNotifications, Boolean isReadingPrependedMessage)
   at Npgsql.NpgsqlDataReader.NextResult(Boolean async, Boolean isConsuming, CancellationToken cancellationToken)
   at Npgsql.NpgsqlCommand.ExecuteReader(CommandBehavior behavior, Boolean async, CancellationToken cancellationToken)
   at Npgsql.NpgsqlCommand.ExecuteDbDataReaderAsync(CommandBehavior behavior, CancellationToken cancellationToken)
   at Integration.Crm.Engine.SqlDatabaseClient.Execute(String statement, SqlQueryParameter[] parameters, CancellationToken token)
   at Integration.Crm.Engine.ScenarioProcessorBase.ProcessSQLDatabaseQuery(ISQLClientFactory sqlClientFactory, ScenarioQuery query, IValueManager customManager, SqlQueryParameter[] queryParameters, CancellationToken token)
   at Integration.Crm.Engine.ScenarioProcessorBase.ProcessScenario(ProtocolScenario scenario, IValueManager customManager, SqlQueryParameter[] sqlQueryParameter, CancellationToken token)
   at Integration.Crm.Engine.ScenarioProcessorBase.Execute(ProtocolScenario scenario, SqlQueryParameter[] sqlQueryParameter, CancellationToken token)
   at Integration.Crm.Engine.CrmProcessor.ExecuteScenarioByName(String scenarioName, IEnumerable`1 parameters, Boolean useNoAuthProvider, CancellationToken token)
   at Integration.Crm.Engine.CrmProcessor.ExecuteScenarioWithRetries(String scenarioId, Dictionary`2 parameters, CancellationToken token)
   at Integration.Crm.Engine.CrmProcessor.ReportCall(CallEndedEvent callEndedEvent, CancellationToken token)
  Exception data:
    Severity: ERROR
    SqlState: 42703
    MessageText: column "callestablishedtimelocal" does not exist
    Position: 185
    File: parse_relation.c
    Line: 3656
    Routine: errorMissingColumn
2024/01/29 15:06:03.855|2828|0022|Trac|Executing SQL: INSERT into cl_party_info (id,dn_type,dn,caller_number,display_name,dn_class,firstlastname,did_number)
Obviously, there is no callEstablishedTime, as the call was not answered.
The reason why I am using callEstablishedTime is because @CallDuration value received via Call Reporting is different from the Talking Time shown in 3CX dashboard.
From what I could tell, talking time in the 3CX dashboard is ` CallEstablishedLocal - CallStartTimeLocal`. While the @CallDuration value, reported by the CallReports is the difference between `CallEndTimeLocal - CallStartTimeLocal`.
Therefore, @CallDuration will always be 2-3 seconds longer than Talking Time.
Just for testing, try the CallStartTimeLocal instead. See if that one works.
TO_CHAR(@CallStartTimeLocal, 'YYYY-MM-DD"T"HH24:MI:SS"Z"')
My guess is the established time is not available since the calls are missed/unanswered, so the call was never "established"/connected/answered.
Yes, that is exactly what is happening.
But the reason why I am using CallEstablished instead of CallStartTime is because I need to calculate the Call Duration.
The @CallDuration value, received from CRM integration, is different from the 'Talking Time' displayed in the 3CX Dashboard, or in the reports.
The @CallDuration value calculates the difference between CallEndTime - CallStartTime, while Talking Time in 3CX probably calculates the difference between CallEndTime - CallEstablishedTime
I understand that. But for missed/unanswered calls, it doesn't matter.
What you can do is use two different chained scenario and have a SkipIf="[CallType]==Missed||[CallType]==Notanswered" in the first scenario (on the Query object to be specific.) This way you can have two different queries and log the StartTime for missed/unanswered.
See the built-in templates for examples.
Oh, ok. Got it. Thanks. I'll give it a try.
@ConceptsWeb
is this what you meant by adding the IF clause and have 2 different queries?
Code:
    <Parameters>
        <Parameter Name="ReportAnsweredCallSQLStatement" Type="String" Parent="General Configuration" Editor="Sql" Title="Call Journaling Answered Calls SQL Statement:" />
        <Parameter Name="ReportUnansweredCallSQLStatement" Type="String" Parent="General Configuration" Editor="Sql" Title="Call Journaling Unanswered Calls SQL Statement:" />
    </Parameters>
    <Scenarios>
            <Query SkipIf="[CallType]==Missed||[CallType]==Notanswered" DatabaseType="PostgreSQL" ConnectionString="Server=[Server];Port=[Port];Database=[Database];User Id=[Username];Password=[Password]" StatementPasses="2" Statement="[ReportAnsweredCallSQLStatement]" />
            <Query DatabaseType="PostgreSQL" ConnectionString="Server=[Server];Port=[Port];Database=[Database];User Id=[Username];Password=[Password]" StatementPasses="2" Statement="[ReportAnsweredCallSQLStatement]" />
            <Variables />
        </Scenario>
    </Scenarios>
</Crm>
My SQL Statements would be:
- Answered Calls:
Code:
- Unanswered calls:
Code:
INSERT INTO calls (agent_extension, agent_firstname, agent_lastname, agent_email, number, call_direction, call_type, call_starttime, call_endtime)  VALUES (@Agent, @AgentFirstName, @AgentLastName, @AgentEmail, @Number, @CallDirection, @CallType,  @CallStartTimeLocal,  @CallEndTimeLocal)
The only difference is that for CallStartTime I set value CallEstablishedTimeLocal (when the call is answered) and CallStartTimeLocal when call is not answered
Question:
How can I ensure that ONLY one query will run for the ReportCall Scenario?
@ConceptsWeb
Code:
    <Parameters>
    </Parameters>
    <Scenarios>
            <Variables />
        </Scenario>
    </Scenarios>
</Crm>
- Answered Calls:
Code:
- Unanswered calls:
Code:
Question:
Unfortunately, this template does not work.
Always after I upload the template, the second query will get deleted.
If I use 2 "ReportCall" scenarios, I get syntax error.
Any idea of what I could do ?
thanks.
You need to chain them. Check the XML CRM docs.
You're adding 2 Query elements inside the same Scenario element. You need 2 different scenarios, each one with 1 query. Then, in the Outputs element of the first scenario you specify the Id of the second scenario in the Next attribute.
Could you provide a sample example?
My main goal is to report the call times - for that I have understood that I must used the reserved ID "ReportCall" for the scenario, and without it, I assume I won't have access to the call variables (e.g @Agent, @calltime... ). Is my assumption correct?
Something like this:
XML:
<Scenarios>
      <Variables />
      <Outputs AllowEmpty="true" Next="ReportCall2" />
   </Scenario>
   <Scenario Id="ReportCall2" Type="SQLDatabase">
      <Variables />
   </Scenario>
</Scenarios>
ah, smart. using scenario ID ReportCall, as first, will ensure that I have the variables in my second scenario as well.
I will give it a try, I hope it will work.
Thank you.
Code:
<Scenarios>
        <Variables />
    </Scenario>
        <Query SkipIf="[CallType]==Inbound||[CallType]==Outbound" DatabaseType="PostgreSQL" ConnectionString="Server=[Server];Port=[Port];Database=[Database];User Id=[Username];Password=[Password]" StatementPasses="2" Statement="[ReportUnansweredCallSQLStatement]" />
        <Variables />
    </Scenario>
</Scenarios>
For some reason, now it is logging it twice. Do you know why?
Is it logging it twice for any specific call type?
for answered call types (Inbound / Outbound) .
For unanswered call types I get error
Code:
2024/02/19 16:03:32.864|6188|0040|Info|CRM: about to report 1 calls at maxConcurrency 2
2024/02/19 16:03:32.864|6188|0040|Verb|CRM: Triggering Call Journaling with values - CallType='Notanswered' - PhoneNumber='123123131231' - ContactName='' - AgentExtension='111111' - AgentFirstName='AgentFirstName' - AgentLastName='AgentLastName' - AgentEmail='[email protected]' - ContactRawData='' - StartTime='2/19/2024 3:03:28 PM' - EndTime='2/19/2024 3:03:32 PM' - EstablishedTime='1/1/0001 12:00:00 AM'
2024/02/19 16:03:32.864|6188|0040|Verb|CRM: Processing scenario 'ReportCall'.
2024/02/19 16:03:32.865|6188|0040|Verb|CRM: Executing SQL Query using ConnectionString 'Server=server;Port=5432;Database=3cx;User Id=postgres;Password=postgres' and Query Statement 'INSERT INTO calls (agent_extension, agent_firstname, agent_lastname, agent_email, number, call_direction, call_type, call_starttime, call_endtime)  VALUES (@Agent, @AgentFirstName, @AgentLastName, @AgentEmail, @Number, @CallDirection, @CallType,  @CallEstablishedTimeLocal,  @CallEndTimeLocal)'.
2024/02/19 16:03:32.875|6188|0048|Erro|CRM: Exception during call reporting: Npgsql.PostgresException (0x80004005): 42703: column "callestablishedtimelocal" does not exist
here it is complaining that there is no CallEstablishedTimeLocal because the call type is `Notanswered`.
That is why I want to skip the SQL query statement in first place, because I am aware that CallEstablishedTimeLocal is not set.
MY SQL Statements look like:
Unanswered Calls - Where I use CallStartTimeLocal as value for Call_StartTime
Code:
Answered Calls - Where i use CallEstablishedTimeLocal as value for Call_StartTime
Code:
[CODE]
I will just give up at this point.
Can you try adding the quotes to the strings in the SkipIf attribute? For example:
SkipIf="[CallType]==&quot;Missed&quot;||[CallType]==&quot;Notanswered&quot;"
EMMEPICASA
