Solved Custom System Prompts
Alphabetic
3CX MVP
Hi support
im toying with some prompts and I believe i've found an issue.
Im doing the QCB.
Caller hits 2
<CB_REQ> is triggered
caller presses 1
<CB_BYE> is triggered
the problem comes when they hit 0.
I assume this is supposed to trigger <CB_EDIT_NUM> but instead it appears to be triggering these 3 <PLSENTER><NUMBER_ENT><THENPRESPND>
I cant see where CB_EDIT_NUM comes in to this?
ok may be wrong with this one but I still need to find which audio prompt is being called when it says "please enter number then press hash"
Nevermind..
3CX needs some pokey-jiggery to give the correct file..
(switching between prompts)
hpgitsupport
