Custom templates only available in Pro and Enterprise
Severin Meyer
Today I wanted to alter an existing custom template at a customers site.
After trying to save and apply the changes several times (no dialog about failing) I realized, that the tooltip at the save button is mentioning about the minimum license should be Pro.
I have searched about this change, but have not found any hints.
Wooooww, that's new and can cause problems for many users of the free license.
I've noticed this as well, major headache because I'm only using 3CX to get the hang of PBX tech with some old EOL Cisco 7945Gs
If you just need a little while, you can see for a PoC (temporary upgrade) with your partner (DM us if you don't have one.)
Otherwise, you'll have to upgrade to Pro I guess. Standard is being discontinued except for those who actually pay for it. The license will stop auto-renewing next year at some point.
Also, using old Cisco won't make you learn much. 3CX works much better with modern devices.
amazingbv
