Customer Server Side CRM Integration
WebMediafields
I created an integration for an internal CRM using the server side template editor. I debugged and tested it within the template editor and it worked fine. However when i select it within the 3CX management console i get a 500 internal server error with the following output:
Code:
System.NotImplementedException: The method or operation is not implemented.
   at ConfigurationManagementModel.CfgCrmIntegrationManager.CreateConfObject(ICfgItem cfgItem)
   at ConfigurationManagementModel.CfgItemBase.Link()
   at ConfigurationManagementModel.CfgItemBase.Sync()
   at ConfigurationManagementModel.CfgItemBase.Save()
   at ManagementConsoleJS.Services.Editor.Save()
   at ManagementConsoleJS.Services.EditorService.SaveActiveObject(Int32 id)
   at ManagementConsoleJS.Controllers.EditController.Save(Int32 id)
   at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__12.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__10.MoveNext()
   at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Rethrow(ActionExecutedContext context)
   at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
   at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__14.MoveNext()
   at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.d__22.MoveNext()
   at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Rethrow(ResourceExecutedContext context)
   at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
   at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.d__17.MoveNext()
   at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.d__15.MoveNext()
   at Microsoft.AspNetCore.Builder.RouterMiddleware.d__4.MoveNext()
   at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.d__3.MoveNext()
Any ideas?
We would have to see the template. A common error is not setting the country code. If you didn't do it, please set it to any value (for example US) as it is not used at the moment, but it is required.
costionofrei
