Data Import
DaveA66
Platinum Partner
I have to say my experiences with data import are at best infuriating!!
I have exported the Inbound Rules, made some changes and tried to re-import and it fails.
The columns that it says it's failinmg on (PORTS/MASK) have not even been changed!
Actually finding this feature very poor,
Can anyone post any hints and tips please??
Many thanks!
Dave
Hmm
Not sure if it is the same issue as the SIP trunk has not changed that I am aware of.
How can I see the SIP trunk port number?
Thanks for the reply!
Dave
Actually, do I need to delete all the exisitng rules first?
So I deleted all 150 rules (!) o_O
Now the file imports OK
Yes, you can not overwrite them if they exist (Same as contacts)
abctel2
