bit101 Silver Partner Basic Certified Joined Sep 8, 2020 Messages 179 Reaction score 34 Nov 30, 2021 #1 Hi togehter! In new new 3cx version V18 the windows client does not have yet the Datev integration like in version 16. Do you know when this will be implemented? regards,
edossantos Support Team Staff member Joined Jun 27, 2007 Messages 7,804 Reaction score 2,950 Nov 30, 2021 #2 In order to use the integration with DATEV you need to use the old 3CX client for Windows, which still works in v18. Please check this guide: https://www.3cx.com/docs/datev-crm-integration-pbx/ This is the client you need to use for the integration: https://www.3cx.com/user-manual/installation-windows/ Reactions: Evolute IT
bit101 Silver Partner Basic Certified Joined Sep 8, 2020 Messages 179 Reaction score 34 Dec 1, 2021 #3 OK thanks for that. So that means the 3CX Windows client V16 will continue to be supported? Reactions: edossantos
StefanW Joined Jun 2, 2009 Messages 2,841 Reaction score 1,033 Dec 1, 2021 #4 for the time being yes Reactions: edossantos
