That field is for the caller ID (number) not the caller's name so I would not recommend adding it there. Also what you see in the trace and which parameter you should add the name to depends on your provider and what its settings are.After add the name to SIP trunk Outbound Caller ID and check SIP trace, I can't see in Invite message the value of name, only number of Calling user.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
