Solved Delete Music-on-Hold soundtracks
RBS
There does not seem to be any way to delete a song/soundtrack after uploading it to "music on hold".
Is this really the case?
Windows or Linux?
Windows or Linux?
Linux on Google cloud. I'm afraid to ssh into console and delete files, as they might be linked to a database and could crash the whole pbx.
In V16 alpha 2, when you delete the playlist, all tracks and the playlist directory are deleted.
I can't check that for you on v15.5 SP6 but if you've deleted the playlist, you should be able to safely remove the files from /var/lib/3cxpbx/Instance1/Data/Ivr/Prompts/Playlist/
I never had a playlist, nothing there. Music was uploaded on the tab next to it, "General MOH"
Ok. I uploaded test.wav to Music File 1
I tested it for playability.
I reset the entry to blank for Music File 1
I logged in to SSH and navigated to: /var/lib/3cxpbx/Instance1/Data/Ivr/Prompts
I did: sudo rm test.wav
Nothing is broken. Everything works fine.
Confirmed "ssh method", nothing broke. Thank you.
It would make so much sense to have a delete button on web panel.
Reactions: MHedish
apbGroup
