Deleting extension doesn't remove BLF entry on other extensions!
ebrowne_sts
Platinum Partner
Hey, we are having an issue where deleting an extension doesn't also delete its BLF entries on other extensions. I ran into this issue before on another 3CX but didn't report it assuming it would be fixed eventually. The logs are littered with the below error because of it:
Is there a reason deleting the extension doesn't also remove it from all places its referenced like in version 18. I now have to go to every extension that has deleted extensions as BLFs and remove one by one.
Is there a plan to fix this behavior in an upcoming update?
Reactions: bitn2
Lol, the double quotes was my issue. Changing to single quotes for the credentials and fqdn worked.
Reactions: KyriacosS_3CX
Okay, that means you use some / or & or some other char in the password that does not work.
Great you found that, and thank you for sharing !
Paulo
Paulo
Thanks for the script and helping me troubleshoot
Does MFA need to be disabled on the system owner extension for this to work?
no
If you fill the variable SecurityCode during the auth procedure with the token then it will work, look:
It's a powershell script with gui, look at token (not used in the picture).
no
Thanks for that clarity.
Interesting looking tool in the screenshot. Is it available to the public?
yes
This is a program for converting a DTS (Deutsche Telefon Standard) SIP trunk to a DTS / NFON SIP trunk flexx (plusnet template).
yes
Oh ok, its template specific. I thought it read all fields for any existing trunk and lets you change to another by swapping out the needed fields
later...
it's been sitting here half-finished for months...
Reactions: ebrowne_sts
ARKC
