Desktop App Ringing ends Teams call (and vice versa) (Jabra specfic issue)
SPembo
We've been troubleshooting an issue whereby Teams and 3CX cut eachother off when other rings whilst in a call. So worth posting here should anyone else be suffering the same issue. Issue appears to exist in versions:
18.12.402
18.11.1213
But not
18.10.461
Issue only occurs when Headset integration is selected, using WebHID driver. On the newest beta version, issue doesn't occur with Jabra selected.
Reactions: AMSIT
Having the exact same issue with both Jabra headsets and EPOS/Sennheiser headsets.
Do you know how I update to the beta version?
Same here, did you find a workaround?
Workaround is to select None for headset integration. I imagine next version very shortly, given it recently went Alpha, so rolling out new client will also resolve i guess.
sherry reynolds
