Dial 0 for reception using SIP ID
Mark Phillips
Last week, I set the SIP ID on a reception phone to 0, thus meaning that any extension could simply dial 0 to call the reception. This worked immediately and without any further configuration.
Now, for some reason, it has stopped working and I see the message "[Flow] Target endpoint for 0 can not be built!" in the activity log. Clearly I am missing something as I think this error is being generated by the Outbound Rules processing...and I believe that a direct SIP call should bypass Outbound Rules all together.
Any ideas?
Mark
Reactions: curtisi
Did you make changes to the outbound rules, an entry that begins with zero? Do you have rules that begin with zero tbut don't have a set number of digits in length? Something must have changed for this to stop working. In the past, I've found the SIP ID to take precedence over outbound rules.
my only outbound rules are:
Prefixed with 9 -> strip 9 -> send to SIP trunk
Length of 7, prefixed with 9 -> strip 9 and add local area code -> send to SIP trunk
Length of 11 -> send to SIP trunk
Length of 6 -> prepend local area code -> send to SIP trunk
Yep, definitely getting caught in outbound rule processing - here's an extract from the verbose log (read bottom up).
12/03/2019 19:30:12 - [CM503016]: Call(C:395): Attempt to reach <sip:[email protected]:5060> from Extn:0002 has failed. Reason: Not Found
12/03/2019 19:30:12 - [CM503014]: Call(C:395): No known route from Extn:0002 to target: <sip:[email protected]:5060>
12/03/2019 19:30:12 - Call(C:395): from Extn:0002 to 0 doesn't match any outbound rule. No outbound rule could be selected.
12/03/2019 19:30:12 - [Flow] Target endpoint for 0 can not be built!
12/03/2019 19:30:12 - Looking for outbound rule: dialed = [0], processed: [0]; from-ext:
12/03/2019 19:30:12 - [Flow] Building target endpoint to 0 from "Joe Bloggs" <sip:[email protected]:5060>
12/03/2019 19:30:12 - [CM503010]: Call(C:395): Making route(s) from Extn:0002 to <sip:[email protected]:5060>
I had the exact same issue that you are describing, I deleted and recreated the dummy user and it worked. If you are not using a dummy user then try to make a dummy user and forward to the reception user.
Why were you using the SIP ID for that? The operator extension setting under General Settings should already do that.
If a user dials 0 from any phone this will not connect to the operator will it without SIP ID?
No, I misread that part. Never had that request so I didn't think of it from that side. I guess anyone who had a need to dial the receptionist either can remember the extension or we put a BLF for it. Odd that it should work and then hit the outbound rules. I also noticed you have extension 0002 in that log. Was that edited or do you actually have extensions with leading zeroes? Or did the change the log formatting and I didn't notice.
We have had quite a few requests for this, as on legacy systems such as Avaya and Samsung this was a widely used feature. This is also sometimes used when a client puts a phone on the wall with a note to dial 0 for entry.
Hmm.. I've replaced a few legacy systems and never had this request, but I never sold legacy systems. And for door entry, it seems that note could just as easily say dial '100' or have a BLF or if I'm replacing the system put an actual door phone. But I guess there is a use case for most anything. But regardless it's definitely odd that is just stopped working. Curious to see what the resolution is.
The reason for wanting to do this is because we have a phone in a public area (in a small hotel) and we want to keep things as simple as possible - therefore "press 0 for reception". It seems fairly common (in UK hotels at least) to dial 0 to speak to reception.
The 0002 extension is one of my testing extensions. The "real" extensions start at 1000. Though I definitely have previously set the SIP ID to 0 on extn 0002 during testing.
Okay found it - :rolleyes:
Under Settings->Network->Direct SIP, I must have un-checked "Allow calls from/to external SIP URIs" at some point, thinking that "external" meant external callers. I have checked the box and now I am able to dial 0 to call the extension.
Reactions: ooki and curtisi
Ok, you've convinced me! I'm making sure all installs can now press 0 to reach the operator! :)
In all seriousness though, that's why I hang out here on the forums. While we see a lot in what we do, there's obviously a lot of different scenarios we don't see. And with 3CX being what it is a lot of times we try to focus on the why people do things as 3CX doesn't replicate a lot of common features of legacy PBXes but can be configured to accomplish the same goal in other ways.
Thanks for updating the thread with the 'fix'
Texas Clay -
