kwriley87 Joined Jan 24, 2017 Messages 15 Reaction score 0 Feb 12, 2019 #1 Is it possible to add a caller ID prefix on a DID? Example: In FreePBX you can append a caller ID prefix on a DID to something like SALES: Is this possible with 3CX?
cobaltit Platinum Partner Advanced Certified Joined Mar 22, 2012 Messages 6,735 Reaction score 2,324 Feb 12, 2019 #2 Yes
kwriley87 Joined Jan 24, 2017 Messages 15 Reaction score 0 Feb 12, 2019 #3 Would you be so kind as to point me in the right direction? I am not seeing this option when assigning inbound routes.
cobaltit Platinum Partner Advanced Certified Joined Mar 22, 2012 Messages 6,735 Reaction score 2,324 Feb 12, 2019 #4 It's not there. It's in the settings section under contacts
kwriley87 Joined Jan 24, 2017 Messages 15 Reaction score 0 Feb 12, 2019 #5 Forgive the ignorance -- this looks like a section to manage the company directory of some sort. I don't see the ability to prefix the caller ID for a specific inbound DID number on the PBX.
cobaltit Platinum Partner Advanced Certified Joined Mar 22, 2012 Messages 6,735 Reaction score 2,324 Feb 12, 2019 #6 It's options, not settings under Contacts
YiannisH_3CX Support Team Staff member 3CX Support Joined May 10, 2016 Messages 11,811 Reaction score 1,797 Feb 12, 2019 #7 Hello @kwriley87 You will need to create an Inbound rule for your DID and name is SALES for example. Then enable the option @cobaltit mentioned.
