Solved DIDs and outbound
cyberbitz
I have two phone DID numbers with nvoip.com.br How can I select via dial which one for example 9 + number for one DID (Goiania) and 8 + number (Sao Paulo) for the other DID location?
Hi @cyberbitz,
You can add separate outbound rules, for example one with the prefix 9, and select the SIP Trunk and strip 1 digit. In the outbound CallerID, place your DID number for that rule.
Thanks, so for example:
SIP1
Main Trunk No: 123456789 set to 23456789
Then Configure Outbound Caller ID to: 123456789
SIP2
Main Trunk No: 987654321 set to 87654321
Then Configure Outbound Caller ID to: 987654321
Hi @cyberbitz,
Better to have it something like this:
Thanks for the visual, helped. Thats awesome.
Reactions: VasilisV_3CX
No problem @cyberbitz, feel free to open a new thread if you require any further assistance.
awan05
