Solved DID's not routing correctly
RobReeves
Hi folk, my gaffer has provisioned a new customer and wants me to setup DID's for each extension,
I've assigned a DID to one to begin with, called it, and it went to the ring group instead of the extension;
Sip Trunk
Pegasus Main Office sip.3cxhostedvoip.co.uk Provider Main line 01613790128
DID/DDI Number
01613790128
*3790383
*3790384
*3790385
*3790386
*3790387
*3790388
*3790389
Inbound Rules
DID All Calls 01613790128 801 Main Office 201 Victoria
DID Greg DID *3790383 203 Greg 203 Greg
DID Test *3790389 802 Test 802 test
Ring Group 801 Main Office
Ring All
Members 201 202 203 205
DID Assigned
01613790128 (801,801)
Ring Group 802 Test
Ring All
Members 501
DID Assigned
*3790389 (802,802)
Calls to any number (01613790128 or 01613790383 - 9) go to the 801 - Main Office ring group.
Greg has the DID set on his extension, the test extension is in the ring group 802 instead of having the DID set specifically to that extension.
Tried with the full number in the DID, 01613790383 and with the wildcard *3790383, not tried going as low as *0383 though....
Maybe if I set the primary DID to use the wildcard too?
Anyone have any ideas?
I would run a wireshark and dial one of your DIDs to see what your provider is sending
Reactions: RobReeves
Perhaps your provider is sending the called number on a different SIP field than the one you have configured. Check the activity log as @kieferschild suggested and check an incoming Invite.
That should help you configure your trunk correctly.
Got it! Wireshark shown that the trunk was sending the main sip number each time, checking on the trunk, the DDI's were configured to route to the main number instead of routing as DDI's with individual numbers.
Set those correctly and now working :D
Thanks guys!
Reactions: YiannisH_3CX
EMMEPICASA
