DID's Stopped working
P_Rice
It seems that sometime last week our DID's stopped routing and all calls have been going to our receptionist. We're a low volume incoming call company, so it wasn't until I was in the office today and got complaints that certain DIDs were no longer ringing the correct ring groups or users; including my own.
I recreated two DID rules and have had the same results.
Also restarted services once.
On-Premise Linux, 18.0 (Build 312), Pro License
Have you tried forwarding as CID in the incoming call rule?
You'll need to enable verbose logs, then make a test call and review the activity log. This should tell you what's happening and why.
But likely your provider is sending the DIDs in a different format.
Who is the provider? How is your trunk/did rules setup (screenshots help).
Please check the SIP Trunk, is this still allowing Inbound and Outbound calls? If not, please re-add the Checkmark.
The provider is WireTap Telecom. I've had the DIDs setup as both E.164 and as 10digit. I have a quick Verbose log dump, and it looks like my CID is coming in as e.164, and wiretap is referencing the DID number as 10digit. I can follow the logs to see where it's going, but not sure how to decipher why. I do see an alert-info line of Alert-Info: <http://www.notused.invalidtld>;info=external
I can post the log tomorrow at some point, but need time to scrub numbers and IP addresses.
Does any of this info help?
Hi Jed,
I just confirmed both are and have been checked off. It's not that calls aren't coming thru, they are just not going where the rules point them.
Reactions: jed
OK, just wanted to check, as we did have this unchecked on a SIP Trunk after an update for one customer.
For what it is worth, we add a * in front of all DID´s to ensure that we catch no-matter how the number comes in.
Hi Jed,
Thanks for the idea, I may try that in the future. As an update, this appears to be solved. I toggled "Call Source Identification" on/off. At that point any DIDs (2 I was testing with) in E.164 stopped working all together. After putting them back into 10digit, they were working fine again (after hours rules), so I will have to check the daytime rules tomorrow. But it seems that had I just had everything in 10digit (which is the orginal format) I would have solved it all by toggling Call Source ID.
Not sure why this happened, but small matter as we were still getting calls; just our 'receptionist' had to work a bit more the last few days on the phones. We've gone to mostly direct dials and IVRs, so that personnel role hasn't been a true receptionist for years.
Thank you all for the ideas and support!
Reactions: jed
Happy to see it is solved
For what it is worth, we all a * in front of all DID´s to ensure that we catch no-matter how the number comes in.
We don't do the star anymore because of SMS, but this used to be how we did it.
Reactions: jed
Hi P_Rice. We're happy to hear that this is resolved. Please don't hesitate to contact us in the future at our helpdesk if you need any assistance. We're here to help!
Happy Tuesday!
AshleyStokes
