Digital Receptionist is not working anymore, just dial tone there
Simon Schäffler
Hey everyone,
we have a problem which occured out of nowhere yesterday. We have 3cx Phone System v.14
Normally if a external persons calls our general phone number he will here immediately the digital receptionist, where he can select numbers for a specific destination.
Since yesterday lunch time, you hear the digital receptionist not anymore, but you will hear a ringing / dial tone. There is nothing happening further.. call will not be terminated, forwarded not even pressing a number is working.
I investigating the problem now for 1 day.. maybe there is something screwed up with the Webserver IIS, due to Windows Update. System is running on a Windows Server 2008 R2.
As well we installed SSL certificate yesterday morning on this server, but the phone system was working for a few hours after that process.
Logfile says the following after a call to the general number:
Code:
05-Oct-2018 07:51:52.073   Leg L:22.2[Ivr:597] is terminated: Cause: BYE from PBX
05-Oct-2018 07:51:52.073   [CM503008]: Call(C:22): Call is terminated
05-Oct-2018 07:51:52.071   Leg L:22.1[Line:10000<<+436645998123] is terminated: Cause: BYE from 185.67.108.5:5060
05-Oct-2018 07:51:49.923   Currently active calls - 2: [20,22]
05-Oct-2018 07:51:49.804   [CM503007]: Call(C:22): Ivr:597 has joined, contact <sip:[email protected]:5483>
05-Oct-2018 07:51:49.803   [CM503007]: Call(C:22): Line:10000<<+436645998123 has joined, contact <sip:[email protected]:5060>
05-Oct-2018 07:51:49.797   L:22.2[Ivr:597] has joined to L:22.1[Line:10000<<+436645998123]
05-Oct-2018 07:51:49.797   NAT/ALG check:L:22.2[Ivr:597] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
05-Oct-2018 07:51:49.597   [CM503025]: Call(C:22): Calling T:Ivr:597@[Dev:sip:[email protected]:5483;rinstance=8d8b16eb7029aabe] for L:22.1[Line:10000<<+436645998123]
05-Oct-2018 07:51:49.548   [CM503027]: Call(C:22): From: Line:10000<<+436645998123 (<sip:[email protected]:5060>)  to  T:Ivr:597@[Dev:sip:[email protected]:5483;rinstance=8d8b16eb7029aabe]
05-Oct-2018 07:51:49.548   [CM503004]: Call(C:22): Route 1: from L:22.1[Line:10000<<+436645998123] to T:Ivr:597@[Dev:sip:[email protected]:5483;rinstance=8d8b16eb7029aabe]
05-Oct-2018 07:51:49.547   [CM505003]: Provider:[hotze] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:104.155.50.224:5060]
05-Oct-2018 07:51:49.546   [CM503001]: Call(C:22): Incoming call from Line:10000<<+436645998123 to <sip:[email protected]:5060>
05-Oct-2018 07:51:49.546   Line limit check: Current # of calls for line Lc:10000(@hotze[<sip:[email protected]:5060>]) is 2; limit is 16
05-Oct-2018 07:51:49.546   NAT/ALG check:L:22.1[Line:10000<<+436645998123] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
   Media session IP ('c=' attribute) is not equal to the IP specified in contact header:
      Media session IP:185.67.108.4
      Contact IP:185.67.108.5
   Media session IP ('c=' attribute) is not equal to the SIP packet source(IP:port):
      Media session IP: 185.67.108.4
      Received from: 185.67.108.5
05-Oct-2018 07:51:49.545   [MS006000] C:22.1: connection address is enforced to 104.155.50.224
05-Oct-2018 07:51:49.543   [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:597
05-Oct-2018 07:51:17.922   Currently active calls - 1: [20]
Hopefully somebody can help me with that problem or see's a problem which I can't see at the moment.. Is it a problem to install SSL certificate on the server AFTER the phone system was installed and running?
Thanks in advance,
Simon
Hello @Simon Schäffler
I would recommend upgrading the system to the latest version as soon as possible as you will have issues with activation in the immediate future (you should have received an email regarding this). After the upgrade check if the issue persists.
Zexus
