Digital Receptionist - Not responding to user key press
tremmert
When a call comes in, the Digital Receptionist takes the call and plays a message "press 1 for blah, 2 for blah, etc. If the user presses a key, the prompt continues to play. Only after the prompt finishes playing can the user press a key to connect to a department.
How can I configure 3CX to immediately respond when someone presses a key?
This should not be the case, are you using a 3CX Supported Provider?
We are self hosting on Digital Ocean.
You should be able to select the options while the prompt is playing.
Understood. Any thoughts as what might be wrong?
tdzski5
