Digital receptionist not working on second sip trunk
rakhim ford
I have two sip trunks
The digital receptionist is set up on one and works successfully
I have a second SIP trunk which is the existing numbers - inbound and outbound calls work fine but digital receptionist menu options will not work I can hear the recording but unable to use the options 1-4
Any advice?
Any advice?
Check the DTMF type of the second trunk and make sure on the provider side that it is set to RFC.
Reactions: YiannisH_3CX
postmaster@studiolegaleda
