Disabling Call Parking
christz
Hello fellows,
I would like to stop agents in Queues from parking calls. How I can do this in 3CX v20?
I dont think this is possible.
you'd have to set call parking spaces to 0 but this would be global and then use orbital parking.
Even if I set parking space to 0 still agents have options to park calls.
I would like to remove the parking option totally so that even agents can not have the option to park calls.
Make sure the role of the ext is user
Yeah all agents role is user.
But still parking option is there
if they can still see parking option from the panel then you've set the permissions under the view tab
Nothing set on view tab
circusduck
