Does 3CX have Auto dialer functionality
aslampa
Is it possible 3CX to dial the leads automatically with an autodialer to the agent and client. At the same time agent need to get a pop from CRM/3CX with customer info and enquiry
Dialer - Yes part of CFD - https://www.3cx.com/docs/cfd-predictive-dialer/ You need Pro or Enterprise license for CFD
If you want to manually dial numbers, if your crm is web based you can use click to call - https://www.3cx.com/phone-system/click-to-call/
CRM intergration what crm application do you use ?
3CX can intergrate with some crm applications - https://www.3cx.com/call-center/crm-integration/
If your application is not on the list, you could try and build your own - https://www.3cx.com/blog/releases/crm-template-generator-pbx/
[email protected].
