Elatix And Linux Time
kareem1
Hi Again
i have an elastix server which as usual works fine with me :)
but my elastix time(wrong time) is equal to my linux time(the correct one) + 1 hour
how can i make the linux and elastix time the same?
note:
the reporting is using my linux time.
There is 2 time sources on Elastix the system and hardware clock. To sync the 2 type "hwclock -w" into your console.
the date/time still greater than my actual time i have tried to update it from the module but it doesn't changed
Log into the Linux console and set the date with the date command. This will make sure it is correct
Urs_S4A
