Email template file location?
ConvergiaDaniel
I'm curious where the 3CX email template files are stored.
As far as I'm aware, there are parameters in Settings > Parameters that contain the styling of these emails in xml formatting, but they do not contain the body of their respective emails.
I would like to change the body contents of the templates, however I can't seem to find anything that's a file I can edit in my Linux installations' directories.
Yes, I'm aware I can change the body of each template through Settings > Email > Email Templates. However, my goal is to change them via the command-line or just by uploading my changes en mass.
Maybe Voiptools has something that allows this? Idk, I would really like something more solid than having to use my auto-hotkey script to make changes in the Settings > Email > Email Templates location.
Thanks,
Daniel
My guess is it is embedded in the database.
On my Windows install - I only see a Template folder located at c:\programdata\3cx\instance1\data\http and c:\programdata\3cx\data\http
Reactions: JoelDean
3K8iMGWviZ
