Enable Provisioning Secret Key
Rick-Arcus-IT
Platinum Partner
This looks like a new 18.6 functionality in Security -> Anti Hacking but I can't find anything about it. Could somebody from 3CX explain what this option does?
Rick
So, when enabled this will create a temp provisioning link for when you set up IP Phones. Be wary that DHCP option 66 wont work with this enabled.
So, when enabled this will create a temp provisioning link for when you set up IP Phones so it cannot be reused. Be wary that DHCP option 66 wont work with this enabled.
Alright, so that would only work with manually entering the provisioning URL in the phones. Thank you for your explanation!
In the past 3CX had a single provisioning URL. With this option enabled, each and every added IP Phone will get a unique URL that only works for that one phone.
The rest remains exactly the same, you don't need to manually add the URL if you weren't doing so already.
Alright, thanks John! This case can be closed.
Jeremy Hofex
