Solved Error 12294 ID500
Luis Bartel
Good afternoon everyone
Recently I installed a PBX 3CX to one of my clients, I find that from time to time it shows me errors in the calls and an occasional delay of up to 10 seconds for a call to be made or entered.
It shows me the following errors:
SIP Server / Call Manager ID: 12294
Call or Registration to 25522850 @ (Ln.10001@Platica-CargoTGU) has failed. 181.114.59.180 replied: 500 Service Unavailable; from IP: 181.114.59.180: 5060
Call or Registration to 25590179 @ (Ln.10001@Platica-CargoTGU) has failed. 0.0.0.0 replied: 408 Request Timeout; internal
I have this SIP with other clients and it works perfect, it is not the firewall since it passes the tests.
So if it's the same configuration as others and the same provider then I'm guessing it's a network issue. The first shows a response from the provider so they are the ones you can tell you why it was rejected. The second is a timeout which means it didn't get a response in time which leans towards a network issue.
Thanks, it was indeed a network error, we had a point-to-point link with the SIP provider and this had non-stable response times.
I changed the logging of the trunks so that it went out the route of my ISP and I don't have this problem anymore.
Thank you so much.
Glad you figured it out and thanks for updating the thread.
devo.it
