Error 487 Request Terminated/INVITE from 127.0.0.1:5483
desmccarthy
New User
I am hosting 3cx on digital ocean and using Did Logic to sip trunking and 3cx softphone. Outbound calls work ok. but I have a problem with inbound calls.
With inbound calls, it rings once, and then silence. The softphone registers a missing call. below are the verbose logs. Any ideas?
11/14/2022 1:25:17 PM - Leg L:15.2[Extn:1000] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
11/14/2022 1:25:17 PM - [CM503003]: Call(C:15): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
11/14/2022 1:25:17 PM - [CM503008]: Call(C:15): Call is terminated
11/14/2022 1:25:17 PM - Leg L:15.1[Line:10000<<34663248003] is terminated: Cause: CANCEL from 157.230.96.24:5060
11/14/2022 1:25:17 PM - [CM503025]: Call(C:15): Calling T:Extn:1000@[Dev:sip:[email protected]:5483;rinstance=6145d53f2efc5f7f] for L:15.1[Line:10000<<34663248003]
11/14/2022 1:25:17 PM - [CM503027]: Call(C:15): From: Line:10000<<34663248003 (":Madrid Number" <sip:[email protected]:5060>) to T:Extn:1000@[Dev:sip:[email protected]:5483;rinstance=6145d53f2efc5f7f]
11/14/2022 1:25:17 PM - [CM503004]: Call(C:15): Route 1: from L:15.1[Line:10000<<34663248003] to T:Extn:1000@[Dev:sip:[email protected]:5483;rinstance=6145d53f2efc5f7f]
11/14/2022 1:25:17 PM - [Flow] No office hours set, office hours assumed
11/14/2022 1:25:17 PM - [Flow] Call(C:15): has built target endpoint: Extn:1000 for call from L:15.1[Line:10000<<34663248003]
11/14/2022 1:25:17 PM - [Flow] Target endpoint for 1000 is Extn:1000
11/14/2022 1:25:17 PM - [CM503010]: Call(C:15): Making route(s) from Line:10000<<34663248003 to <sip:[email protected]:5060/UDP>
11/14/2022 1:25:17 PM - [CM505003]: Provider:[DID Logic] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:5060]
11/14/2022 1:25:17 PM - [CM500002]: Call(C:15): Info on incoming INVITE from Line:10000<<34663248003: Invite-IN Recv Req INVITE from 157.230.96.24:5060 tid=175f.f2af460571dd9a7369d2910c611dd6b4.2 Call-ID=[email protected]:5080: INVITE sip:[email protected]:5060;rinstance=7b55e0bd5249794b SIP/2.0 Via: SIP/2.0/UDP 157.230.96.24;branch=z9hG4bK175f.f2af460571dd9a7369d2910c611dd6b4.2 Via: SIP/2.0/UDP 206.191.159.247;rport=5060;branch=z9hG4bK175f.161e3eadd7759a86eda7ad7ba9cebf04.2 Via: SIP/2.0/UDP 72.251.228.147:5080;received=72.251.228.147;branch=z9hG4bK7b508982;rport=5080 Max-Forwards: 68 Record-Route: <sip:157.230.96.24;lr=on;ftag=as5323d94d;vst=AAAAAAEFAQUAcAEFBBgIeQMeBhsIGwYaBTI4LjEy> Record-Route: <sip:206.191.159.247;lr=on;ftag=as5323d94d;vsf=AAAAAAAAAAAAAAAAAAAAAAUCGBwECB8cAw0XHwYDDTUwODA-> Contact: <sip:[email protected]:5080> To: 34910035269 <sip:[email protected]> From: <sip:[email protected]>;tag=as5323d94d Call-ID: [email protected]:5080 CSeq: 102 INVITE Content-Type: application/sdp Content-Length: 352 v=0 o=didlogic 606096621 606096621 IN IP4 72.251.228.147 s=DID Logic GW c=IN IP4 72.251.228.147 t=0 0 m=audio 15034 RTP/AVP 8 0 9 18 3 101 a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:9 G722/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:3 GSM/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20 a=sendrecv
11/14/2022 1:25:17 PM - [CM503001]: Call(C:15): Incoming call from Line:10000<<34663248003 to <sip:[email protected]:5060>
11/14/2022 1:25:17 PM - Line limit check: Current # of calls for line Lc:10000(@did Logic[<sip:[email protected]:5060/UDP>]) is 1; limit is 2
11/14/2022 1:25:17 PM - [CM503012]: Inbound office hours rule (Madrid Number) for 10000 forwards to DN:1000
11/14/2022 1:25:17 PM - [Flow] Looking for inbound target: called=34910035269; caller=<sip:34663248003@:0>
11/14/2022 1:25:02 PM - Settings of Extn:1000 has been updated
Looking at the log entries in your description, the call is CANCELed by 157.230.96.24
This is shown in the following line:
11/14/2022 1:25:17 PM - Leg L:15.1[Line:10000<<34663XXXXXX] is terminated: Cause: CANCEL from 157.230.96.24:5060
This is the IP that the registrar (sip.de.didlogic.net) resolves to so you will need to check this with DID logic.
Please edit your post above and remove any sensitive information about your system (IPs, FQDNs, Extensions, DIDs, etc.).
Reactions: TheodorosG_3CX
i have something close to it, kindly check please
12/21/2022 12:48:40 PM - [CM503003]: Call(C:9790): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
12/21/2022 12:48:40 PM - [CM503003]: Call(C:9790): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
12/21/2022 12:47:18 PM - [CM503003]: Call(C:9785): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
12/21/2022 12:47:17 PM - [CM503003]: Call(C:9787): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
12/21/2022 12:47:17 PM - [CM503003]: Call(C:9787): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
does bold sentence mean computers Network cards (Lan issue) ?
Hi @Mohamedseliem
The entries you see do not indicate an issue necessarily.
You can see such entries when a call comes into a queue or ringgroup and is answered by an extension. These entries will appear for the rest of the extensions because the call that was ringing on each extension stopped (since it was answered).
thanks a lot, how to check if it is an issue or not ?
i mean how to trouble-shoot it
