Solved Everything was good and then suddenly phone firmware is not supported
isaaydin
Hi everyone,
I have configured my phones about 3 months ago and everything in dashboard was showing green and all firmware were updated up to date. And then suddenly I get the firmware is not supported. But everything works great. Is there a way to update them or is there a problem between 3cx and Fanvil? I thought 3CX is upgrading phone firmware automatically when needed or am I wrong?
Screenshot attached. Please advise
Sorry, forget it. I figured it out )) for those who have the same issue, it's done from phones, select the phone and then click firmware.
When phones firmware turns red 3CX console let you know you have to apply manually a new updated release doing the way you've done.
We will release firmware updates periodically, so in case you see the message just check as above.
EMMEPICASA
