- Joined
- Aug 19, 2019
- Messages
- 5
- Reaction score
- 0
We have moved to the next phase of the integration between Odoo and 3CX so now we want to sync the call logs from the 3CX to Odoo. We are using the Call Journalling option in the 3CX Template that is working great for contacts that are already in Odoo, but the issue that we have now is with calls where the contact is not in the CRM system still(first time calls, etc), since current implementation of 3CX as documentation explains will export the log to the CRM only if the contact is found in the CRM. Do you have any suggestions how we can export this call logs from the system to Odoo as well?
One more thing, we want to implement an option that will change user status directly from Odoo so is there an option in the 3CX API that provides such update?
