Extension Import Fail
kriley87
Good morning-
I am trying to turn off call recording for all extensions, so I exported my extension list and disabled this feature and attempted to import the list but the import is failing. As a test, I just simply exported my extension list and attempted to import it, making no changes, and it is still failing:
Your import file has errors. Note that not all rows were imported.
Below is a list of row numbers that failed and in brackets you can see the column header that caused the failure.
2 (Number),
3 (Number),
4 (Number),
5 (Number),
6 (Number),
7 (Number),
8 (Number),
9 (Number),
10 (Number),
11 (Number),
12 (Number),
13 (Number),
14 (Number),
15 (Number),
16 (Number),
17 (Number),
18 (Number),
19 (Number),
20 (Number),
21 (Number),
22 (Number),
23 (Number),
24 (Number),
25 (Number),
26 (Number),
27 (Number),
28 (Number),
29 (Number),
30 (Number),
31 (Number),
32 (Number),
33 (Number),
34 (Number),
35 (Number),
36 (Number),
37 (Number),
38 (Number),
39 (Number),
40 (Number),
41 (Number),
42 (Number),
43 (Number),
44 (Number),
45 (Number),
46 (Number),
47 (Number),
48 (Number),
49 (Number),
50 (Number),
51 (Number),
52 (Number),
53 (Number),
54 (Number),
55 (Number),
56 (Number),
57 (Number),
58 (Number),
59 (Number),
60 (Number),
61 (Number),
62 (Number),
63 (Number),
64 (Number),
65 (Number),
66 (Number),
67 (Number),
68 (Number),
69 (Number),
70 (Number),
71 (Number),
72 (Number),
73 (Number),
74 (Number),
75 (Number),
76 (Number),
77 (Number),
78 (Number)
Any ideas?
Thank you
Easy way, select the extensions by clicking the box next to each extension -you can select more than one and clicking on edit.
Note you can select all extensions, by click in the box in the header line
Ahhh thanks -- I supose I was overcomplicating it :)
Hi @kriley87
Yep, the multi select of extensions is really helpful :)
You cannot import extensions that already exist. You must delete them from the management console and then import them back.
PS: Always create a backup before such an operation so you can return to the way it was before any modifications took place.
[email protected].
