Solved External Calls to DECT Ext Not Working
SocalChris
I have a Yealink W56H that is successfully registered to the base station, and the base station is registered to 3cx successfully, However I am only able to make outbound calls. The extension is online yet when i direct the inbound route directly to the extension it goes straight to voicemail. what would be causing this? I noticed that the in the extension (phones) the DECT doesn't appear.
What do the logs say?
turns out that DND was enabled using the feature code. All good now
The logs are useful :). Glad you figured it out.
WAFI
