External phone number for conferencing-setting missing in v20?
noord
Hello all,
In v20, I cannot seem to find the external number for (old fashioned) conferencing.
The number is still present in the database somewhere and also use in email templates, but I cannot find where the settings had gone and I cannot change the number.
I have a post describing exactly which setting I mean:
https://www.3cx.com/community/threads/v20-old-fashioned-conference-calls.125258/#post-603695
But I created that post in reply on another thread but I'm nog getting any replies there, probably because it has gone unnoticed.
So I am now creating this new thread and pointing to that post. I tried copying the post but I had problems with getting the screen shots over, so that's why I'm pointing to that other post.
I hope you don't mind in this case and that anyone has found where this setting has gone :-)
Thanks for any help!
Admin > System > Conferencing.
It's there.
It's there.
Thanks for your reply, but that is not the number that is used in the email template or the number shown on screen when starting the call.
In v18 it was a separate field. You could even enter something like 1111 in it and that number would be used in the email and shown on screen. It was not the actual number used.
It seems that setting has been forgotten in v20. Perhaps on a new install the field would be empty and when empty, the actual number assigned would be used?
In any case, the reason why it was a separate field in v18 was because the DID could be something like 31851234567 but the number someone has to dial could be displayed as 085-1234567 instead.
Check the system parameters for the number, perhaps it's listed there.
Thanks, I did, couldn’t find it there either.
It seems I have to hack the DB :-)
it is in parameters but its under this name, but would be handy if we didnt have to go into parameters and this field was editable on the conference page.
CONFERENCEMAINNUMBER
Reactions: noord
Reactions: Colby D.
Carlos - EC Mates
