Failed to make out going calls with Cause: 408 Request Timeout/INVITE from local
rbachu
Hi Team,
we have hosted the 3cx on aws and had created SIP trunk with twilio and made the configuration. Incoming calls is working good but the outgoing calls are failing with the below errors
Call to T:Line:10000>>+1xxxxxxxxx@[Dev:sip:[email protected]1.twilio.com:5060;transport=TLS] from L:7.1[Extn:1000] failed, cause: Cause: 408 Request Timeout/INVITE from local
Call(C:7): Call to <sip:[email protected]1.twilio.com:5060> has failed; Cause: 408 Request Timeout/INVITE from local
My env -
  • 3CX Version,16.0.6
  • Is the 3CX Server Hosted and where? Hosted at Amazon aws
  • Trunk Provider : twilio
  • Are custom Phone Templates being used: YES
I am not seeing the call details or errors on the Twilio, seems like the call from the 3cx is not even getting initiated. on the detailed logs,
logs are as follows -
11/13/2020 7:23:09 PM - Default best-route IP is determined as x.x.x.x
11/13/2020 7:23:08 PM - Currently active calls - 1: [9]
11/13/2020 7:22:58 PM - Default best-route IP is determined as x.x.x.x
11/13/2020 7:22:57 PM - [CM503025]: Call(C:9): Calling T:Line:10000>>+1415xxxxxxx@[Dev:sip:[email protected]1.twilio.com:5060;transport=TLS] for L:9.1[Extn:1000]
11/13/2020 7:22:57 PM - Route to L:9.2[Line:10000>>+1415xxxxxxx] sends Invite-OUT Send Req INVITE from 54.172.60.0:5060 tid=0904751bda932526 Call-ID=Z8JrjWmk6mhHFN9pt_5Esw..:
INVITE sip:[email protected]1.twilio.com:5060;transport=TLS SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---0904751bda932526;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5061;transport=TLS>
To: <sip:[email protected]1.twilio.com:5060;transport=TLS>
From: <sip:[email protected]1.twilio.com:5060;transport=TLS>;tag=6500950f
Call-ID: Z8JrjWmk6mhHFN9pt_5Esw..
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 16.0.6.655 (655)
P-Asserted-Identity: <sip:[email protected]1.twilio.com:5060>
Remote-Party-ID: <sip:[email protected]1.twilio.com:5060>;party=calling
Content-Length: 218
v=0
o=3cxPS 29004428757434368 8513782926016513 IN IP4 y.y.y.y
s=3cxPS Audio call
c=IN IP4 y.y.y.y
t=0 0
m=audio 9016 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
help me out with any suggestions..
The reason I ask is because post shows the trunk trying to use TLS but the neither the guide nor the template are configured for TLS so it appears to changed something.
In the link, they have suggested to go to the twilio documentation. and also twilio supports only TLS for the secure trunking - https://www.twilio.com/docs/sip-trunking
Reactions: JohnS_3CX
tohoken1
