Solved Failure to get certificate on new deployment/install
Felicia King
I've setup a new 3CX instance and used a 3cx.us FQDN which should allow for the Let's Encrypt SSL certificates to generate and activate for install on the system. During install, I received failure to activate messages and retried three times. Eventually I told it to generate a self-signed cert. The PBX is up and running and fully updated. I looked for online procedures to force the renewal and activation of the Let's Encrypt SSL on the WAN FQDN, but could only find this https://www.3cx.com/docs/self-hosted-instances-ssh/.
Does anyone have a link to a better article that would indicate the procedure to get the PBX to request and activate a Let's Encrypt SSL cert on 3cx.us WAN FQDN?
The PBX passes firewall checker properly also.
It could be an issue on the LE side. I wouldn't force it as you might hit the limit and then can't get one for a week. It should sort itself out as long as there's no network issue on your end causing the problem.
@cobaltit is right about the limit though, I'd recommend making absolutely sure that there's nothing preventing the renewal from completing successfully, such as network restrictions, before trying it again.
Thank you both. Yes that was the article I was looking for. I did also receive a notification at 1:29A that the cert generated and renewed for validity 90 days. So apparently leaving it alone overnight fixed it.
Glad to hear! Feel free to start a new thread should anything else come up!
mazet
