Solved Fanvil RPS not working (15.5.0)
gbrown100
I have a bunch of Fanvil x3g's - I have set them up as a x3s in 3CX (Apparently that's right) but when I try to provision it fails. Checked event logs and found the following error:
3CX Phone System Management Console ID: 30018
RPS request for Fanvil X3S IP Phone of <My Phone Name> (100) NOT delivered. You will need to configure the phone manually by copying and pasting the provisioning link https://<MyServer>.3cx.co.uk/provisioning/<myprovisionid>/ in the phone web interface. Error Message: <html> <head><title>504 Gateway Time-out</title></head> <body bgcolor="white"> <center><h1>504 Gateway Time-out</h1></center> <hr><center>nginx</center> </body> </html>
This is a PBXExpress in OVH cloud from stock. Have tried in various different servers (all cloud) and it doesn't work. I then have to manually provision them which is a pain.
Does anyone have Fanvil RPS working?
Graham
Does anyone run X3G with 3cx? Should RPS work?
Hi guys,
I checked and it works for me:
Ha ok, well today it works. Been down for a couple of days for me. Sods law it would be the first time I try a Fanvil phone.
Glad to see it is working for you
apbGroup
