Fanvil x6 upgrade caused blf failer
grcomm
Gold Partner
I noticed after upgrading phone to 1.12.4 when an incoming call is parked the light goes blank when it should flash red. If I downgrade park works fine.
vs 16.0.461
Noticed the same issue on 1.12.4 with Fanvil X5S phones. Only seems to affect parked calls.
version 16.0.676
Debian
All devices local with no custom templates.
Thanks, we have already inform Fanvil about this.
They will investigate it and eventually provide us with updated firmware that corrects the behavior.
Ok I believe I have located the problem and correct me if I'm wrong but I believe this is a template issue with the 3cx firmware update. Upon comparing the settings between my X4U (1.0.0) which is working correctly and my X6U (1.0.1) which is not I found the "BLF using LED" dsskey status LED on the X6U was set to off. I attempted to change it but I believe when the phone provisions to my 3cx it reverts back to off.
x4ugui-png.13265
13266
Wecare_ITA
