Fax Server issue
Petersang
Forum User
hello, i make a generic sip trunk (Cisco Gateway) and i have tested inbound and outbound rules for calls and everything is ok, i make a fax server with a specific did number and i make a inbound rule to send the fax to the extension of the fax server and for testing that i called that number from outside and i hear the fax tone but the problem i can't receive the fax, any help ?
So I would first setup a 3CX tested/approved SIP turnk and confirm faxing works there. Then you know 3CX is working and can focus on why they aren't working via your Cisco Gateway.
Just want to add that you can find a list of our Supported providers here along with their FAX Support status: https://www.3cx.com/partners/sip-trunks/
You might also want to consider looking through our forums a bit, perhaps you could find posts with similar situations.
thank you very much
Reactions: ChrisC_3CX
