Solved Feature Request - Show Calling Group in Call list
markus.ehrmann
Hi there 3CX Team,
I was wondering if it would be possible to expand the call list within the Windows app so that it shows when a call has arrived via a call group?
Thanks in advance for your help!
For instance, we have a call group for our main number. However, it's not possible to tell in the call list whether the call came in via the main number or via the direct extension.
On iOS (native call list), you can already see the call group right after the phone number in the call list.
Thank you
Markus Ehrmann
Hi Markus.
You can give the name to the DID so that you know where the call is called to
Reactions: markus.ehrmann
Hi Markus.
Hi Oleg
Thank you for your quick reply. Works fine with the assigned name at the did. So the topic is solved.
Greetings
Markus
Perfect! I will now close this thread.
Have a nice day
Vera Lea Kristensen Raage
