Solved Firewall Test Disables Web Interface
dpenny
I just finished installing v18 of 3CX, self-hosted, using the Linux ISO. After getting the security certificate and DNS all setup, I could access the web management interface with no problem. I ran the firewall test and midway through, the web interface completely stopped responding. The page eventually timed out and I can no longer access the web management interface. I have rebooted the server, but that didn't seem to help. I can ping the server fine, so I know it's up and working, I just can not access the web management interface.
Is there a CLI command I can run to restart the web interface?
Thanks,
Doug
Hi Doug,
If you installed with the 3CX ISO, you can use the following commands to start and stop all 3CX services:
Bash:
/usr/sbin/3CXStopServices
/usr/sbin/3CXStartServices
Give them a shot. If you still can't access the Management Console after this, check if there is anything listening on the HTTP you chose during the installation (usually 80 or 5000):
Bash:
netstat -laputen | grep nginx
Do you see something listening on this ports?
If you do, aalso try accessing the Management Console using the Local IP Address like this: http://<Local IP Address of the 3CX Server>:<HTTP port>
Hi Doug,
Bash:
Bash:
Thanks! Stopping and then starting the services took care of the issue.
Doug
Glad to hear that Doug!
GP Concepts
