Fix "office hours" in CFD
Rogé
I used CFD to create and manage the callflows for my customers. With V18 it worked like a charm but since V20 i have issues with using the opening times. According to some other posts, it seems to be know issue (see links bellow). There is also a work-arround available which let me change the C# code, generated by the CFD. This may work but it makes the wholte thing pretty complex. Near that, i always need to apply the workarround each time i edit the callflow in the designer.
I also read that there is already a fix implemented (and will be released soon according to a post from @Charles_3CX Jan 2024) but there are also thoughts that the new version of the CFD will never be released because of the "C# call flow scripting" feature. The CFD (drag and drop) was realy usefull to me, just developing these flows in C# would be way to complicated/overkill in my case. This because of the lack of C# / 3CX developing knowledge.
Alternatively i can configure the opening times in the CFD but in that case it gets even more complicated as i need to define "opening hours" and "out of office" hours which need to match eachtoher. Also define a "over night" time windows is not possible so... just terrible to do it that way.
A bit off topic, the option to use the "break" times (as separated paramter) in the CFD would be nice as well.
As the last thing i can find about this all is already a few months old, i'm curious if there is an update on this? (previous posts are closed)
Related posts:
https://www.3cx.com/community/threads/cfd-office-hours-out-of-office-hours.128133/
https://www.3cx.com/community/threads/query-department-holiday-from-call-flow-designer.126381/
https://www.3cx.com/community/threads/upgrading-to-v20-with-call-flow-designer.123680/
@NicholasP_3CX I saw you are working for the 3CX support team, maybe you can give an update on this ? (as nobody else is replying)
Reactions: EmmettsIT
I also used the 3CX Office Hours selection in the DateTimeCondition. I haven't gotten it to work. Have you had any success?
It made setting up office hours easy. Would be nice if it worked again.
Is the current 3CX CFD V20.2.84 being used?
No, it is not. I checked for updates, and it didn't find any, so I Assumed it was the current version. Will try and reinstall and see if it works.
Thanks for the fast reply.
KylieWilderman
