Flexible pricing
freshEF
Forum User
We work in a seasonal industry, and during our busy season we get hammered with calls and often exceed our license limit, then in the offseason very few calls.
If you have the annual licensing are you allowed to go up and down as you choose, or is there a limit to it?
So you can replace the key in an installation with another key at any point, but if you did that outside of an annual basis that would cost you more money. There's also no way to replace keys via the management console for hosted by 3CX if you go that route. So realistically your best option is just to budget for your peak call volume and license accordingly.
3CX is extremely cheap. You can simply buy the biggest license you need and it should pay for itself if you get that many calls.
That's simply the way it is.
Tech_Support
